[postgis-devel] Testing on Windows PostGIS 1RC1
Nicklas Avén nicklas.aven at jordogskog.no
Wed Sep 22 11:12:04 PDT 2010
Regina My problem was already when compiling postgresql 9.0I guess I have something outdated. I will try again now and maybe get back if I don't figure out what the error-messege is about. everybody I know I have had some regression tests failiurs on measures the other week. It is one of those small differences and it only shows for me on a ubuntu 32bit installation. On windows (on the same machine as ubuntu 32 bit) and ubuntu 64bit on another box, it passes. Is someone getting running the regression tests on linux 32 bit with sucess on measures? One thing that is a little interesting about it is that the installations that passes regression tests is the same installations that gives the fenomena in #503. So the installations passing the regreesion tests are the same installations as rounds the answer of area to closest multiple of 0.001953125 I just wanted to mention it if it can be a clue for someone smart about #503 /Nicklas
2010-09-22 Paragon Corporation wrote:
>Nicklas,
>> I will try to do some testing this evening. I tried yesterday on windows
>but had problems with compiling postgresql 9.0I don't remember the error
>message now. I will try on another > box. Regina has there been any special
>things compiling 9.0 in mingw for you? I have not updated anything (have
>just been glad it has worked :-) )so maybe I should just reinstall
>> mingw and everything. /Nicklas
>We do use some hacks to compile against PostgreSQL 9.0 on windows that we
>don't need to do for prior versions.
>That's why I said -- maybe the issues I have on Windows are not really a
>good measure of what others will experience and someone needs to test on
>Linux or Mac.
> 1) can't get it to install without this:
>sed 's,$(PERL),perl,g'postgis/Makefile2
>mv postgis/Makefile2 postgis/Makefile
>Which I documented in the PostGIS 1.5 section of
>http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompile
>2) For some reason we can't do a make check against the MingW build of
>PostgreSQL 9.0. It always gives this error
>createdb: could not connect to database postgres: FATAL: parameter "port"
>cannot be changed without restarting the server
>(could be because we have so many versions of PostgreSQL, but the other
>versions of PostgreSQL don't have this issue)
>So to get around this mess -- after make install on MingW, our script copies
>the files to our Windows PostgreSQL 9.0 install and then does the
>make check
>For the others -- make check against the mingW builds works fine and all
>checks for 8.3 and 8.4 against mingW builds pass with flying colors.
>-- Mark to answer your question about the diffs in the PostgreSQL 9.0 --
>they look like below - so it seems to me that the PostgreSQL 9.0 (and it
>could be some default sent in the Windows build just providing the count
>of records (more information) than what the regress is expecting.
>*** wmsservers_expected Tue Nov 17 12:23:16 2009
>--- /tmp/pgis_reg_124/test_46_out Mon Sep 20 08:54:34 2010
>*** 1,6 ****
> Starting up MapServer/Geoserver tests...
> Setting up the data table...
>! SELECT
> NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index
>"wmstest_pkey" for table "wmstest"
> ALTER TABLE
> Running Geoserver 2.0 NG tests...
>--- 1,6 ----
>! SELECT 2343
> ALTER TABLE
>*** tickets_expected Mon Feb 8 14:19:23 2010
>--- /tmp/pgis_reg_124/test_47_out Mon Sep 20 08:54:36 2010
>*** 45,51 ****
> #210b|
> #213|17
> #234|COMPOUNDCURVE((0 0,1 1))
>! SELECT
> #241|0
> #254|010700000000000000
> #259|
>--- 45,51 ----
> #210b|
> #213|17
>! SELECT 1
> #241|0
> #259|
>Thanks,
>Regina
>>> Remember that because postgis_comments.sql has extra dependencies for the
>>documentation build that it needs to be installed from the documentation
>>Makefile. This is now under PGXS control too, so all you need to do is:
>>> cd doc/
>>> make comments-install
>>> ...and you're golden.
>>For this then we probably should put a note somewhere in the docs that if
>>they aren't doing a make install of comments, then the comments will have
>to
>>be manually copied.
>>The point why we package the postgis_comments.sql in the tar is so that
>>people don't need the extra xsltproc dependency and don't need to run the
>>step you describe above. So yah I know the step above works but that is not
>>the point.
>>I'll have to get back to you other issue as I don't have my difffs around.
>>All I recall is the output was something like
>>SELECT 3456
>>And the regress just had
>>SELECT
>>But lets see what others say. We are on windows so who cares since things
>>don't quite work the same for us anyway.
>>Thanks,
>>Regina
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100922/313f83a2/attachment.html>
