[postgis-devel] PostGIS 1.5.2 are we ready for release?
Paul Ramsey pramsey at opengeo.org
Fri Sep 24 11:35:55 PDT 2010
-1, better to make them work, the fix was not hard. Committed at
r6016. Werks for me on my OS. Anyone else?
On Fri, Sep 24, 2010 at 11:26 AM, Paragon Corporation <lr at pcorp.us> wrote:
> +1 Yes lets comment them out.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Friday, September 24, 2010 2:18 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] PostGIS 1.5.2 are we ready for release?
> Well, it's a shame to have regression noise in a final release... and it's a
> shame every new pgsql release gives us new regression issues to work around
> Let me quickly look at those cases, I would vote for commenting them out of
> this release so we don't release aomething with failing 'make check'
> results.
> P.
> On Fri, Sep 24, 2010 at 11:08 AM, Paragon Corporation <lr at pcorp.us> wrote:
>> Paul, Kevin and Mark,
>> You think we are ready for release yet?  Seems fine to me.
>> As far as the 2 errors I got in 9.0.  I confirmed it's a new feature
>> that when you do a SELECT INTO or CREATE TABLE AS
>> The output also gives count of records.  Snippet from release notes:
>> "Make SELECT INTO and CREATE TABLE AS return row counts to the client
>> in their command tags (Boszormenyi Zoltan)
>> This can save an entire round-trip to the client, allowing result
>> counts and pagination to be calculated without an additional COUNT query.
>>  I suppose we can change our regress to do a CREATE and then insert or
>> something, but certainly no reason to hold up the release.
>> Thanks,
>> Regina
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
