[postgis-devel] [PostGIS] #609: Bad source code in manual section 5.2 Java Clients
PostGIS trac at osgeo.org
Sat Sep 25 12:12:54 PDT 2010
 Reporter:  simoc                      |       Owner:  pramsey
     Type:  defect                     |      Status:  new
 Priority:  low                        |   Milestone:  PostGIS 1.5.2
Component:  postgis                    |     Version:  1.5.X
 Keywords:  JDBC client documentation  |
 I found some errors in the example Java source code in section 5.2 'Java
 Clients (JDBC)' of postgis-1.5.1.pdf:
 Replace:
 ((org.postgresql.Connection)conn).addDataType("geometry","org.postgis.PGgeometry");
 ((org.postgresql.Connection)conn).addDataType("box3d","org.postgis.PGbox3d");
 with:
 ((org.postgresql.jdbc3.Jdbc3Connection)conn).addDataType("geometry","org.postgis.PGgeometry");
 ((org.postgresql.jdbc3.Jdbc3Connection)conn).addDataType("box3d","org.postgis.PGbox3d");
 Replace:
 ResultSet r = s.executeQuery("select ST_AsText(geom) as geom,id from
 geomtable");
 with:
 ResultSet r = s.executeQuery("select geom,id from geomtable");
 Replace:
 if( geom.getType() = Geometry.POLYGON ) {
 with:
 if( geom.getGeoType() == Geometry.POLYGON ) {
Ticket URL: <http://trac.osgeo.org/postgis/ticket/609>
