[postgis-devel] [PostGIS] #610: raster: Can't build with raster
PostGIS trac at osgeo.org
Tue Sep 28 21:47:36 PDT 2010
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 This may just be a MingW  issue, but I can't build PostGIS 2.0 with
 --with-raster.  It seems like the later rt-make is ignoring my custom GDAL
 configuration though configure correctly picks it up.
 Anyrate if someone else can check on their platform, that would be great.
 Also I'm sure Paul and Jorge were discussing this, though I didn't
 udnerstand anything they were saying:  IS there is a reason why we need a
 separate rt-install.  Why can't it be like --with-gui where when you say
 that it builds the make and all that for the gui and if you don't it
 doesn't?
 -- Getting back to my problem --
 -- my configure looks like this
 ./configure --with-gdal=/c/projects/gdal/rel-trunk/bin/gdal-config
 --prefix=/c/projects/pg/pg91 --with-
 xml2config=/c/projects/libxml/libxml2-2.7.6release/bin/xml2-config --with-
 pgconfig=/c/projects/pg/pg91/bin/pg_config --with-
 geosconfig=/c/projects/geos/rel-trunk/bin/geos-config --with-
 projdir=/c/projects/proj/rel-4.6.1 --with-gui --with-raster
 -- and generates an output which looks like this (as you can see GDAL is
 being picked up --
  PostGIS is now configured for i686-pc-mingw32
  -------------- Compiler Info -------------
   C compiler:           gcc -g -O2
   C++ compiler:         g++ -g -O2
  -------------- Dependencies --------------
   GEOS config:          /c/projects/geos/rel-3.3.0/bin/geos-config
   GEOS version:         3.3.0
   GDAL config:          /c/projects/gdal/rel-trunk/bin/gdal-config
   GDAL version:         1.8.0
   PostgreSQL config:    /c/projects/pg/pg91/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.1alpha1
   PROJ4 version:        46
   Libxml2 config:
   Libxml2 version:      2.7.6
   PostGIS debug level:  0
  -------------- Extensions --------------
   PostGIS Raster:       0.1.6d
 But in the raster compile -- it gives all sorts ofo errors which I recall
 getting before when the gdal config path is not set.
 Generating PostGIS Raster stuff
 make -C raster all
 make[1]: Entering directory `/c/projects/PostGIS/trunk/raster'
 make -C rt_core
 make[2]: Entering directory `/c/projects/PostGIS/trunk/raster/rt_core'
 gcc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-prototypes
 -Ic:/projects/PostGIS/trunk/liblwgeom     -c -o rt_api.o rt_api.c
 In file included from rt_api.c:33:
 rt_api.h:89:22: gdal_alg.h: No such file or directory
 rt_api.h:90:24: gdal_frmts.h: No such file or directory
 rt_api.h:91:18: gdal.h: No such file or directory
 rt_api.h:92:21: ogr_api.h: No such file or directory
 rt_api.c: In function `rt_raster_dump_as_polygons':
 rt_api.c:1406: error: `GDALDataType' undeclared (first use in this
 function)
 rt_api.c:1406: error: (Each undeclared identifier is reported only once
 rt_api.c:1406: error: for each function it appears in.)
 rt_api.c:1406: error: syntax error before "nPixelType"
 rt_api.c:1408: error: `OGRSFDriverH' undeclared (first use in this
 function)
 rt_api.c:1408: error: syntax error before "ogr_drv"
 rt_api.c:1409: error: `GDALDriverH' undeclared (first use in this
 function)
 rt_api.c:1410: error: `GDALDatasetH' undeclared (first use in this
 function)
 don't have an issue compiling the old wktraster standalone.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/610>
