[postgis-devel] [PostGIS] #885: pgsql2shp fields conversion from predefined list
PostGIS trac at osgeo.org
Sun Apr 3 02:31:24 PDT 2011
  Reporter:  rodo         |       Owner:  loic
      Type:  enhancement  |      Status:  reopened
  Priority:  medium       |   Milestone:  PostGIS 2.0.0
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:
Comment(by loic):
 By "ensure unique name" spot of the code I assume you are refering to
 loader/pgsql2shp-core.c lines
 #!C
                  * make sure the fields all have unique names,
                 tmpint = 1;
                 for (j = 0; j < state->fieldcount; j++)
                         if (!strncasecmp(dbffieldname,
 state->dbffieldnames[j], 10))
                                 sprintf(dbffieldname, "%.7s_%.2d", ptr,
 tmpint++);
                                 continue;
 which are left untouched by the patch and occur after the mapping function
 is called:
 #!diff
 -               dbffieldname = malloc(11);
 -               strncpy(dbffieldname, ptr, 10);
 -               dbffieldname[10] = '\0';
 +               dbffieldname = ShpDumperFieldnameLimit(ptr, state);
 My reasoning for keeping this part is that if, presumably by mistake, the
 provided symbol map contains duplicates, enforcing uniqueness will help
 ensure the consistency of the generated file. If the map does not produce
 duplicate symbols, the {{{make sure the fields all have unique names}}}
 lines will do nothing.
 Am I making sense ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/885#comment:8>
