[postgis-devel] [PostGIS] #339: [raster] Implement ST_Band function for raster
PostGIS trac at osgeo.org
Tue Apr 5 21:19:52 PDT 2011
 Reporter:  mloskot         |       Owner:  pracine
     Type:  task            |      Status:  new
 Priority:  low             |   Milestone:  PostGIS Raster Future
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 As part of the FV.01, I propose the following function versions for
 ST_Band:
 ST_Band(rast raster, nbands int[]) -> raster
     nbands is an array of 1-based band indices of the bands to copy into
 the output raster
     Ex: For a raster rast with 3 bands:
         ST_Band(rast, ARRAY[1,3,2])
         ST_Band(rast, ARRAY[3,2,1])
         You can rearrange the bands as above. You can also duplicate the
 bands:
         ST_Band(rast, ARRAY[1,2,3,2,1])
 ST_Band(rast raster, nband int) -> raster
     nband is a single integer of the 1-based band index of the band to
 copy into the output raster
     Ex: ST_Band(rast, 1)
         ST_Band(rast, 3)
 ST_Band(rast raster, nbands text) -> raster
     nbands is a comma separated string of 1-based band indices indicating
 the bands to copy into the output raster
     Ex: ST_Band(rast, '1,2')
         ST_Band(rast, '1,2,3, 1, 1 , 2')
 ST_Band(rast raster)
     the band to extract is automatically assumed to be one.
     Ex: ST_Band(rast) -> raster
 Should I include a expanded version of the ST_Band(rast raster, nbands
 text) to provide the ability to specify the delimiter?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/339#comment:10>
