[postgis-devel] [PostGIS] #902: [raster] ST_MinMax
PostGIS trac at osgeo.org
Fri Apr 8 06:59:47 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS Raster Future
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Additional variations of the ST_MinMax function
 ST_MinMax(rast raster, nband int, ignore_nodata boolean) -> set of record
 (min float8, max float8)
   instruct the function to ignore NODATA values in the band
 ST_MinMax(rast raster, ignore_nodata boolean) -> set of record (min
 float8, max float8)
   assume band index = 1
 The prior two versions of the function
 ST_MinMax(rast raster, nband int) -> set of record
 ST_MinMax(rast raster) -> set of record
 will also assume that ignore_nodata is TRUE.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/902#comment:2>
