[postgis-devel] [PostGIS] #819: topology: error on regress of createtopogeom
PostGIS trac at osgeo.org
Sat Apr 9 15:18:29 PDT 2011
  Reporter:  aperi2007  |       Owner:  strk
      Type:  defect     |      Status:  reopened
  Priority:  medium     |   Milestone:  PostGIS 2.0.0
 Component:  topology   |     Version:  trunk
Resolution:             |    Keywords:
Comment(by aperi2007):
 I don't sure to understand what error was issuing.
 I see this error message.
  regress/createtopogeom. failed (diff expected obtained:
 /tmp/pgis_reg_9628/test_16_diff)
 Run tests: 21
 Failed: 1
 make[2]: *** [check] Error 1
 make[2]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/topology/test'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/topology'
 make: *** [check] Error 1
 But the logs generated are two "pgis_reg_5400 " and "pgis_reg_9628"
 I put both in the zip added.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/819#comment:13>
