[postgis-devel] (no subject)
Paragon Corporation lr at pcorp.us
Sun Apr 10 08:22:27 PDT 2011
http://www.postgis.org/documentation/manual-svn/PostGIS_FAQ.html#id2823937
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Sunday, April 10, 2011 10:04 AM
To: PostGIS Development Discussion
Cc: postgis-devel at postgis.refractions.net
Subject: Re: [postgis-devel] (no subject)
Problem is likely with the bytea encoding change in 9.0 make sure you also
upgrade your pgsql jar.
P.
On 2011-04-08, at 6:40 AM, RANDYHORNER <randy.horner at nisc.coop> wrote:
> Thanks for the response.   I wanted to keep it short and I had hoped the
> answer was obvious and the java code has a dumb error on my part.  I
> had not worked on this for some time so I'm not exactly sure what has
changed.
> postgis_1.3.3.jar to postgis-1.5.0.jar but backing up did not help.  I
> do not believe the data changed.  I believe we've also upgraded to
postgresql
> 9.0.
> "POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August 2008"
> LIBXML="2.7.6" USE_STATS"
> http://old.nabble.com/%28no-subject%29-tp31341827p31351834.html
> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
