[postgis-devel] [PostGIS] #862: Topology: the topology.DropTopology() drop any type of schemas
trac at osgeo.org
Wed Apr 13 02:26:36 PDT 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Comment(by strk):
The idea behind dropping indiscriminately everything was based on the fact
that you _might_ have messed up with topology.topology thus missing the
"blessing" of a schema as a topology.
This is pretty much like DropGeometryTable, where the table is dropped
even if it isn't advertised in geometry_columns, and even if it doesn't
contain any geometric column...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/862#comment:1>
