[postgis-devel] [PostGIS] #625: make clean does not clean raster
PostGIS trac at osgeo.org
Wed Apr 13 10:58:39 PDT 2011
  Reporter:  robe     |       Owner:  jorgearevalo
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 I don't recall it to be an issue, so will close this out,  but
 unfortunately our development environment is a bit in shambles at the
 moment since we are in the middle of switching to use mingw-64 build
 environment.
 We'll bug you later strk -- having issues with compiling GEOS under
 mingw-64, but will battle it a bit more before we bug you.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/625#comment:3>
