[postgis-devel] Problems compiling GEOS 3.3.0 with MngW-64
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Apr 14 02:26:32 PDT 2011
On 13/04/11 23:18, Paragon Corporation wrote:
> We are setting up our MingW64 environments with the hopes of compiling both
> 32-bit and 64-bit PostGIS 2.0.
Good choice - the MingW64 guys have been really helpful to me in the past :)
> That said we have run into stumbling blocks with compiling GEOS 3.3.0 under
> this environment.  Right now we are just trying on a 32-bit, but will be
> dong the same on our 64-bit windows 7 soon.
> Attached is the log of our compile.
(cut)
> I've cc'd PostGIS dev in case Mark C. or anyone else hhas any thoughts:
> The instructions we are putting together are here:
> http://trac.osgeo.org/postgis/wiki/DevWikiWinMingW64
This is all great stuff. Some initial thoughts: firstly it's good to see
that you're building recent versions of autotools - I've lost count of
the number of times my Win32 builds failed because the provided
autotools were old :(
Secondly, this bug below:
   //using ::swprintf;
   //using ::vswprintf;
Was fixed upstream in MingW so shouldn't be necessary anymore if you're
running with recent headers.
There are a various errors showing up here, but I would suggest raising
the following errors as a starting point on the mingw-w64-public list
here: https://lists.sourceforge.net/lists/listinfo/mingw-w64-public.
1) warning: right shift count >= width of type
I suspect this is because sizeof(*foo) != sizeof(long) on Win64 but the
MingW-w64 guys will be able to sort this out easily. I suspect it will
need changes committed to GEOS in order to handle the different variable
size.
2) From the GEOS build:
/bin/sh ../../libtool --tag=CC   --mode=link i686-w64-mingw32-gcc
-pedantic -Wall -ansi -Wno-long-long  -ffloat-store -g -O2   -o
libindex.la   bintree/libindexbintree.la chain/libindexchain.la
intervalrtree/libintervalrtree.la quadtree/libindexquadtree.la
strtree/libindexstrtree.la sweepline/libindexsweepline.la
libtool: link: (cd .libs/libindex.lax/libindexbintree.a &&
i686-w64-mingw32-ar x
"/c/projects/geos/trunk/src/index/bintree/.libs/libindexbintree.a")
File not found - *.o
libtool: link: (cd .libs/libindex.lax/libindexchain.a &&
"/c/projects/geos/trunk/src/index/chain/.libs/libindexchain.a")
libtool: link: (cd .libs/libindex.lax/libintervalrtree.a &&
"/c/projects/geos/trunk/src/index/intervalrtree/.libs/libintervalrtree.a")
libtool: link: (cd .libs/libindex.lax/libindexquadtree.a &&
"/c/projects/geos/trunk/src/index/quadtree/.libs/libindexquadtree.a")
libtool: link: (cd .libs/libindex.lax/libindexstrtree.a &&
"/c/projects/geos/trunk/src/index/strtree/.libs/libindexstrtree.a")
libtool: link: (cd .libs/libindex.lax/libindexsweepline.a &&
"/c/projects/geos/trunk/src/index/sweepline/.libs/libindexsweepline.a")
libtool: link: i686-w64-mingw32-ar cru .libs/libindex.a
libtool: link: i686-w64-mingw32-ranlib .libs/libindex.a
libtool: link: rm -fr .libs/libindex.lax
libtool: link: ( cd ".libs" && rm -f "libindex.la" && cp -p
"../libindex.la" "libindex.la" )
This is why the final link is failing because some files are being
omitted from the libraries - could be one of either a Windows
native/MingW path issue or a bug in autotools.
Once you've managed to get these issues resolved (which I don't think
will take too long), I'm happy to take another look and see if I can
help you out again.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
