[postgis-devel] SnapToGrid support of circular string
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Apr 14 02:30:16 PDT 2011
On 13/04/11 21:24, Sandro Santilli wrote:
> Does it make sense to threat a CircularString the
> same as a LineString when it comes to snapping it
> to a grid ?
> Adding such support would help fixing ticket #183,
> which is a regress test failing due to precision on 32bits:
>   COMPOUNDCURVE(
>     CIRCULARSTRING(0 0,0.500000000000184 1.20710678118655,1 0),
>     (1 0,0 1)
> Sorry for the lame question but I haven't found semantic
> of CIRCULARSTRING on the postgis manual
I think you need to consult the SQL-MM specification for this - I'm not
sure whether snapping should just affect control points or something else?
Can you post a reference when you find out what the behaviour should be
so it is documented for the archives?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
