[postgis-devel] [PostGIS] #914: legacy.sql install failing on can't find chip
PostGIS trac at osgeo.org
Mon Apr 18 07:17:34 PDT 2011
 Reporter:  robe     |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I think its probably best to just move chip and chip related functions out
 of legacy.sql altogether into a separate legacy_chip.sql.in.c since it is
 probably even less likely to be used than the others.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/914>
