[postgis-devel] [PostGIS] #903: [raster] ST_Reclass
PostGIS trac at osgeo.org
Tue Apr 19 08:49:06 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS Raster Future
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 The reason I added the nodata parameter is that when the new band is
 created (old band -> reclass -> new band), the attributes hasnodata and
 nodataval of the new rt_band can be assigned.  Without that assignment,
 setting the new band's pixel value to NULL is ambiguous.
 As for your example...
 ST_Reclass(rast, 1, '0-100:1-10, 101-500:11-150,501 - 10000: 151-254, 255:
 NULL', '8BUI')
 I'm assuming that the format for "255:NULL" is different from "0-100:1-10"
 and does not conform to rangefrom:rangeto.  Is this correct?  And that
 "255:NULL" means "The value 255 is the NODATA value for the output band"?
 If so, isn't this a bit confusing?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/903#comment:12>
