[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
PostGIS trac at osgeo.org
Wed Apr 20 11:10:09 PDT 2011
 Reporter:  pracine         |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 This is strange as I did the test of simplifying RASTER_getPixelValue to
 return a constant float value and I there was no more memory growth... Did
 you remove everything related to context in this simplified version?
 What if you do:
 CREATE TABLE toto AS
 SELECT x, y FROM generate_series(1, 10) x, generate_series(1, 10) y,
 srtm_35_04_10x10;
 instead?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:24>
