[postgis-devel] [PostGIS] #920: CURVEPOLYGON problem when converting to/from text
PostGIS trac at osgeo.org
Thu Apr 21 09:01:18 PDT 2011
 Reporter:  debe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.3
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 i have a problem with this geometry:
 CURVEPOLYGON(COMPOUNDCURVE((724190.669216162
 120573.733407055),CIRCULARSTRING(724190.669216162
 120573.733407055,724190.12214281 120573.55
 7014059,724189.632 120573.341),(724189.632 120573.341,724189.874
 120573.455,724190.122 120573.557,724190.375 120573.647,724190.631 120573.
 724,724190.669216162 120573.733407055)))
 that is generated from (that polygon is a result of a st_intersection with
 others geometries):
 st_linetocurve(st_geomfromtext('POLYGON((724190.669216162
 120573.733407055,724190.631098529 120573.723945555,724190.3745717
 120573.646726888,724190.12214281 120573.557014059,724189.874419981
 120573.455023195,724189.632 120573.341,724189.874 120573.455,724190.122
 120573.557,724190.375 120573.647,724190.631 120573.724,724190.669216162
 120573.733407055))'))
 if i convert it to text and i convert it back to geometry
 st_geomfromtext(st_astext(geometry))
 i receive this error:
 ERROR:  geometry requires more points
 HINT:  "...E((724190.669216162 120573.733407055)" <-- parse error at
 position 62 within geometry
 is this a bug or i'm doing something wrong?
                                         postgis_full_version
  POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August 2008"
 LIBXML="2.6.32" USE_STATS
Ticket URL: <http://trac.osgeo.org/postgis/ticket/920>
