[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
PostGIS trac at osgeo.org
Sun Apr 24 19:34:50 PDT 2011
 Reporter:  pracine         |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 I solved this problem. I've reviewed the entire memory management system
 of PostGIS Raster, and changed several things. Now rt_core/rt_pg work in
 the same way liblwgeom/postgis do. Same philosopy. Same memory contexts.
 All core and regression tests pass but 2. I'm working to solve them. As
 soon as I fix them, I'll commit the code.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:29>
