[postgis-devel] [PostGIS] #930: [raster] ST_SummaryStats
PostGIS trac at osgeo.org
Fri Apr 29 11:11:39 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS Raster Future
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 "ignore_nodata boolean" should be replaced with "hasnodata boolean " to be
 more consistent with the way we already specify to take into account or
 ignore nodata values in ST_Intersects and eventually in ST_DumpAsPolygons
 and ST_Intersection. The logic, in this case, is inverted: when FALSE we
 do not take nodata values into account.
 Users can also normally just do
 ST_SummaryStats(ST_SetBandNoDataValue(rast, NULL)) to get the same result.
 We expect to have a similar set of function taking a geometry (any kind:
 multipoint, lines, polygons) to limit the stats to the area of this
 Thanks dustymugs
Ticket URL: <http://trac.osgeo.org/postgis/ticket/930#comment:1>
