[postgis-devel] Fwd: Build failed in Hudson: PostGIS-trunk-build #2157
Olivier Courtin olivier.courtin at oslandia.com
Fri Apr 29 11:20:10 PDT 2011
On Apr 29, 2011, at 7:53 PM, kneufeld at refractions.net wrote:
Currently build is broken,
Looks like it's related to docs part.
but the log is not that clear and i can't reproduce it on my local
server.
(i.e i can still do a make docs, and a make check in docs retrieve few
errors,
but nothing that serious)
Sounds familliar to someone ?
> See <http://office.refractions.net:1500/job/PostGIS-trunk-build/2157/changes
> Changes:
> [Courtin Olivier] Add an srid default value as second optional
> parameter for ST_GeomFromGML. Related to #906. Remove a wrong
> srsName definition. Update doc and unit test
> [...truncated 492 lines...]
> generating ../images/st_issimple06.png
> generating ../images/st_issimple07.png
> generating ../images/st_isvalid01.png
> generating ../images/st_isvalid02.png
> generating ../images/st_isvalid03.png
> generating ../images/st_isvalid04.png
> generating ../images/st_isvalid05.png
> generating ../images/st_isvalid06.png
> generating ../images/st_isvalid07.png
> generating ../images/st_isvalid08.png
> generating ../images/st_isvalid09.png
> generating ../images/st_linecrossingdirection01.png
> generating ../images/st_linecrossingdirection02.png
> generating ../images/st_linecrossingdirection03.png
> generating ../images/st_linecrossingdirection04.png
> generating ../images/st_line_interpolate_point01.png
> generating ../images/st_line_substring01.png
> generating ../images/st_longestline01.png
> generating ../images/st_longestline02.png
> generating ../images/st_longestline03.png
> generating ../images/st_minimumboundingcircle01.png
> generating ../images/st_sharedpaths01.png
> generating ../images/st_sharedpaths02.png
> generating ../images/st_shortestline01.png
> generating ../images/st_shortestline02.png
> generating ../images/st_snap01.png
> generating ../images/st_snap02.png
> generating ../images/st_snap03.png
> generating ../images/st_snap04.png
> generating ../images/st_snap05.png
> generating ../images/st_split01.png
> generating ../images/st_split02.png
> generating ../images/st_split03.png
> generating ../images/st_split04.png
> generating ../images/st_symdifference01.png
> generating ../images/st_symdifference02.png
> generating ../images/st_touches01.png
> generating ../images/st_touches02.png
> generating ../images/st_touches03.png
> generating ../images/st_touches04.png
> generating ../images/st_touches05.png
> generating ../images/st_touches06.png
> generating ../images/st_within01.png
> generating ../images/de9im03.png
> convert ../images/de9im03.png -resize 100x100 ../images/de9im03.png
> generating ../images/de9im04.png
> convert ../images/de9im04.png -resize 100x100 ../images/de9im04.png
> generating ../images/de9im05.png
> convert ../images/de9im05.png -resize 100x100 ../images/de9im05.png
> generating ../images/de9im06.png
> convert ../images/de9im06.png -resize 100x100 ../images/de9im06.png
> generating ../images/de9im07.png
> convert ../images/de9im07.png -resize 100x100 ../images/de9im07.png
> generating ../images/de9im08.png
> convert ../images/de9im08.png -resize 100x100 ../images/de9im08.png
> generating ../images/de9im09.png
> convert ../images/de9im09.png -resize 100x100 ../images/de9im09.png
> generating ../images/de9im10.png
> convert ../images/de9im10.png -resize 100x100 ../images/de9im10.png
> generating ../images/de9im11.png
> convert ../images/de9im11.png -resize 100x100 ../images/de9im11.png
> generating ../images/de9im12.png
> convert ../images/de9im12.png -resize 100x100 ../images/de9im12.png
> generating ../images/de9im13.png
> convert ../images/de9im13.png -resize 100x100 ../images/de9im13.png
> make[1]: Leaving directory `<http://office.refractions.net:1500/job/PostGIS-trunk-build/ws/build/doc/html/image_src'
> /usr/bin/xsltproc --param section.autolabel 1 --param
> section.label.includes.component.label 1 --param chunk.section.depth
> 0 --param generate.section.toc.level 1 --param funcsynopsis.style
> ansi --param admon.graphics 1 --param admon.textlabel 0 --param
> simplesect.in.toc 0 --param use.id.as.filename 1 --param
> chunk.quietly 1 --stringparam html.stylesheet style.css  \
> 		--output html/ \
> 		--stringparam saxon.character.representation decimal \
> 		/usr/share/sgml/docbook/xsl-stylesheets/html/chunk.xsl \
> 		postgis-out.xml
> Link element has no content and no Endterm. Nothing to show in the
> link to
> link to
> + make comments
> + tee -a doc-errors.log
> /usr/bin/xsltproc ./xsl/postgis_comments.sql.xsl postgis.xml >
> /usr/bin/xsltproc ./xsl/raster_comments.sql.xsl postgis.xml >
> raster_comments.sql
> + make pdf
> make -C html/image_src images
> make[1]: Entering directory `<http://office.refractions.net:1500/job/PostGIS-trunk-build/ws/build/doc/html/image_src'
> make[1]: Nothing to be done for `images'.
> Build the listings...
> http://www.oasis-open.org/docbook/xml/4.5/ent/isopub.ent:1: parser
> error : Content error in the external subset
> HTTP/1.1 200 OK
> HTTP/1.1 200 OK
> HTTP/1.1 200 OK
> unable to parse <http://office.refractions.net:1500/job/PostGIS-trunk-build/ws/build/doc/postgis-out.xml
> Error: xsltproc failed
> make: *** [postgis-2.0.0SVN.pdf] Error 1
> + rm -f postgis.xml
> + mv postgis.xml.orig postgis.xml
> ++ grep Error doc-errors.log
> ++ wc -l
> + '[' 2 -gt 0 ']'
> + cat doc-errors.log
> /usr/bin/xsltproc ./xsl/postgis_aggs_mm.xml.xsl postgis.xml >
> postgis_aggs_mm.xml
> cat postgis.xml | sed "s/@@LAST_RELEASE_VERSION@@/2.0.0SVN/g" >
> postgis-out.xml
> gcc -g -O2  -Wall -Wmissing-prototypes -I../../../liblwgeom -c -o
> styles.o styles.c
> generator.o generator.c
> gcc -o generator styles.o generator.o ../../../liblwgeom/liblwgeom.a
> -lm -lcunit
> generating ../images/de9im01.png
> generating ../images/de9im02.png
> generating ../images/st_azimuth01.png
> generating ../images/st_azimuth02.png
> generating ../images/st_buffer01.png
> generating ../images/st_buffer02.png
> generating ../images/st_buffer03.png
> generating ../images/st_buffer04.png
> generating ../images/st_buffer05.png
> generating ../images/st_buffer06.png
> generating ../images/st_buffer07.png
> generating ../images/st_buffer08.png
> generating ../images/st_buildarea01.png
> generating ../images/st_buildarea02.png
> generating ../images/st_closestpoint01.png
> generating ../images/st_closestpoint02.png
> generating ../images/st_centroid01.png
> generating ../images/st_centroid02.png
> generating ../images/st_centroid03.png
> generating ../images/st_centroid04.png
> generating ../images/st_contains01.png
> generating ../images/st_contains02.png
> generating ../images/st_contains03.png
> generating ../images/st_contains04.png
> generating ../images/st_contains05.png
> generating ../images/st_contains06.png
> generating ../images/st_concavehull01.png
> generating ../images/st_concavehull02.png
> generating ../images/st_concavehull03.png
> generating ../images/st_concavehull04.png
> generating ../images/st_concavehull05.png
> generating ../images/st_concavehull06.png
> generating ../images/st_concavehull07.png
> generating ../images/st_concavehull08.png
> generating ../images/st_convexhull01.png
> generating ../images/st_crosses01.png
> generating ../images/st_crosses02.png
> generating ../images/st_crosses03.png
> generating ../images/st_crosses04.png
> generating ../images/st_difference01.png
> generating ../images/st_dumppoints01.png
> generating ../images/st_issimple01.png
> generating ../images/st_issimple02.png
> generating ../images/st_issimple03.png
> generating ../images/st_issimple04.png
> generating ../images/st_issimple05.png
> 		--output html/ \
> 		postgis-out.xml
> link to
> link to
> raster_comments.sql
> HTTP/1.1 200 OK
> HTTP/1.1 200 OK
> HTTP/1.1 200 OK
> + exit 1
> Archiving artifacts
Olivier
