[postgis-devel] [PostGIS] #1123: Create a legacy_compatibility_layer.sql.in.c
trac at osgeo.org
Wed Aug 3 11:00:06 PDT 2011
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
I've done the creation of this file in r7693 which contains ndims and srid
functions needed to restore data from tables created using the old
populate_geometry_columns.
I'm thinking that as part of the upgrade_minor script I should have a
helper function that runs looking for tables built with the old named
constraints and rebuild the containts using the new names so that when
uninstall_legacy.sql is run, its less likely to error out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1123#comment:3>
