[postgis-devel] [PostGIS] #1148: Geocoder has poor results with correct inputs
PostGIS trac at osgeo.org
Thu Aug 4 10:54:19 PDT 2011
 Reporter:  darkblueb       |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Okay I think this one is a typo in tiger data.
 This query should give me all the streets that are around the right
 location of El Cajon Fremont, CA
 SELECT f.*, e.lfromadd, e.ltoadd, e.rfromadd, e.zipl,
 ST_AsText(ST_Centroid(the_geom)) As b
         from tiger_data.ca_edges As e INNER JOIN tiger_data.ca_featnames
 AS f ON e.tlid = f.tlid where
 ST_DWithin(ST_GeomFromText('POINT(-122.024396
 37.558286)',4269),the_geom,0.005)
 order by ST_Distance(ST_GeomFromText('POINT(-122.024396
 37.558286)',4269),e.the_geom), f.fullname
 limit 10;
 If I run the above query, the first match I get is
 El Canon Ave
 Looking at Google, I think that should be El Cajon.
 I haven't had a chance to look at your other entries -- does that file
 just contain all failures or is it a mishmush of failures and successes?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1148#comment:11>
