[postgis-devel] [PostGIS] #1118: Street pretypes that aren't directional prefixes
PostGIS trac at osgeo.org
Thu Aug 4 17:14:56 PDT 2011
 Reporter:  robe            |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  1.5.X
 Keywords:                  |
Comment(by robe):
 More examples of this issue:
 1798 PASEO DEL CAJON, PLEASANTON, CA 94566
 Doesn't geocode right but this does: with a bad rating but returns right
 answer
 SELECT pprint_addy(addy), ST_AsText(ST_SnapToGrid(geomout,0.0001)) As
 coord, rating
         FROM geocode('1798 PSO DEL CAJON, PLEASANTON, CA 94566',1) As g;
 Behavior of pretypabrs is a little different from highway.  Both require
 fixes in the normalize_address so I'll probably add another column in
 street_typelookup to fix these.
 Most often if it has a pretype it doesn't have a street type that falls at
 the end.  Though in some cases it can have both.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1118#comment:2>
