[postgis-devel] [PostGIS] #1152: SRID_MAXIMUM should be raised, gserialized_get/set_srid () should be patched and typemod int too
trac at osgeo.org
Sun Aug 7 06:46:14 PDT 2011
Reporter: vince | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: invalid | Keywords: srid liblwgeom
Comment(by robe):
I have a somewhat unpleasant compromise to this which assumes there is
nothing in the geometry itself being constrained by typmod and its just at
the typmod column definition level.
I'm sure Paul and Mark and many others will oppose vehemently. The issue
is mostly typmod? We still support the old way using maintenance
functions and in fact raster doesn't even support typmod and I don't see
how it can at least not for a very long while.
Move the constraint out and have it only apply for geometry columns
created using typmod. Then when PostgreSQL finally changes typmod to
support 64-bit we can relax again. This check is easy to put in for
maintenance functions to check SRID and if above limit for typmod throw a
warning and use the old way.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1152#comment:8>
