[postgis-devel] [PostGIS] #1155: Can't compile PostGIS 2.0 under mingW
trac at osgeo.org
Mon Aug 8 04:06:48 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: windows mingw |
strk,
With the latest trunk r7709, I can no longer compile PostGIS 2.0 under
MingW.
Attached is full build.log
excerpts that look like the critical area
Info: resolving _xmlFree by linking to __imp__xmlFree (auto-import)
C:\MinGW\bin\..\lib\gcc\mingw32\3.4.5\..\..\..\..\mingw32\bin\ld.exe:
warning: auto-importing has been activated without --enable-auto-import
specified on the command line.
This should work unless it involves constant data structures referencing
symbols from auto-imported DLLs.
../liblwgeom/liblwgeom.a(lwgeom_geos.o): In function `GEOS2LWGEOM':
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:98: undefined reference
to `GEOSGetSRID'
../liblwgeom/liblwgeom.a(lwgeom_geos.o): In function `LWGEOM2GEOS':
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:299: undefined reference
to `GEOSGeom_createLineString'
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:314: undefined reference
to `GEOSGeom_createLinearRing'
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:315: undefined reference
to `GEOSGeom_createPolygon'
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:323: undefined reference
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:333: undefined reference
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:344: undefined reference
`lwgeom_intersection':
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:457: undefined reference
to `GEOSIntersection'
`LWGEOM_GEOS_buildArea':
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:766: undefined reference
to `GEOSGetSRID'
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:839: undefined reference
to `GEOSCoordSeq_clone'
c:/projects/PostGIS/trunk/liblwgeom/lwgeom_geos.c:842: undefined reference
collect2: ld returned 1 exit status
C:\MinGW\bin\dllwrap.exe: C:\MinGW\bin\gcc exited with status 1
make[1]: *** [postgis-2.0.dll] Error 1
make[1]: Leaving directory `/c/projects/PostGIS/trunk/postgis'
make: *** [all] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1155>
