[postgis-devel] [PostGIS] #1053: Make transformation and projection cache API available.
PostGIS trac at osgeo.org
Thu Aug 11 01:16:26 PDT 2011
 Reporter:  bnordgren    |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by mcayland):
 -1 for patch application.
 Having reviewed the patch, it does not seem to be up to date with the
 latest discussions on the mailing list. The approach should be to put the
 transformation code in liblwgeom and link that against the raster .so, not
 separate it out into another entity. Unfortunately this will mean some
 refactoring of the projection API as dicussed onlist, but this patch is
 currently going in the opposite way we need to be heading.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1053#comment:9>
