[postgis-devel] [PostGIS] #1053: Make transformation and projection cache API available.
PostGIS trac at osgeo.org
Fri Aug 12 08:18:40 PDT 2011
 Reporter:  bnordgren    |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by bnordgren):
 Ok, I think I see what happened. I never enabled raster without also
 applying the patch on #1058, which contains the fix.  Grrr.
 It's a one-liner: just change
 #include "../../postgis/gserialized.h"
 to
 #include "gserialized.h"
 As long as you've run ./configure after applying the patch, it'll pick it
 up. I'll upload a new patch (with $Id$ hunks removed) shortly. This one
 just built with --enable-raster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1053#comment:21>
