[postgis-devel] [PostGIS] #1053: Make transformation and projection cache API available.
PostGIS trac at osgeo.org
Fri Aug 12 08:31:31 PDT 2011
 Reporter:  bnordgren    |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 I've pushed a cleaned up version of the patch to a 'libpgcommon' branch on
 github.
 Hopefully that way others can have an easier time testing it and cleaning
 it further before application into SVN.
 Assuming you've a recent enough git, this should do to fetch:
 git clone --branch libpgcommon --depth 1 github.com:strk/postgis.git
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1053#comment:24>
