[postgis-devel] [PostGIS] #1157: generating documentation takes forever
PostGIS trac at osgeo.org
Fri Aug 12 11:58:23 PDT 2011
  Reporter:  strk     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  wontfix  |    Keywords:
Changes (by chodgson):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 I think we've agreed that it is wrong to repackage the MathML and/or
 docbook DTDs. If you want to not download them every time, then you need
 to install them locally. For reasonably recent distros, you should be able
 to apt-get/yum them from your repository, you need mathml2 and docbook-
 mathml2 (or something like that). For older or less helpful distros you
 can download the packages from their respective sources and fiddle with
 your xml catalog files to get xsltproc to find them.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1157#comment:1>
