[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
PostGIS trac at osgeo.org
Sat Aug 13 07:54:43 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by bnordgren):
 Replying to [comment:5 strk]:
 > Regina, libpgcommon is actually using PGSQL_BE_CPPFLAGS, so _should_ be
 finding everything needed for postgresql... where's your netdb.h ? I have
 one in /usr/include and a few under postgresql-
 xxx/include/server/port/win32. I suspect PGXS would take care of adding
 -I.../port for win32
 I added PGSQL_BE_CPPFLAGS myself, as the result of `$PGCONFIG
 --includedir-server` so if we figure out what else needs to be added for
 Windows, this is the place to put it. Is the netdb.h file in any of the
 directories which can be mined from pg_config?
 I'm not using PGXS because, as I read it, it makes *.so files and complete
 postgresql extension modules. `libpgcommon` needs to be static.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:9>
