[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
trac at osgeo.org
Sun Aug 14 21:40:34 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Sadly my postgis.dll built doesn't on my 9.0 doesn't work and fails on
regress with this:
BEGIN
psql:c:/projects/PostGIS/trunk/regress/postgis.sql:63: ERROR:
incompatible library "c:/projects/PostGIS/trunk/regress/00-regress-
install/lib/postgis-2.0.dll": missing magic block
HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:19>
