[postgis-devel] [PostGIS] #1160: operator = returns wrong results checking two POINTS
PostGIS trac at osgeo.org
Tue Aug 16 03:26:33 PDT 2011
 Reporter:  gabrimonfa  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  postgis     |     Version:  1.5.X
 Keywords:              |
 The query
 SELECT '0101000000EC51B85E200D3A4114AE47318E635241'::geometry =
 '010100000052B81E45200D3A417B14AE378E635241'::geometry;
 should return false since the two POINTS are different.
 I have tried on 1.5.3 (current stable).
 The problem is probably present also on older releases (I've tried on
 1.5.2 compiled by source and on 1.3.3)
 In current (2011-08-16) 2.0.0SVN the query returns the correct result
 (confirmed by strk on IRC)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1160>
