[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
trac at osgeo.org
Tue Aug 16 20:02:13 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
strk with r7757 that fixes my ability to compile to a raster dll for my
9.0. However I still have the more pressing problem that the dll it
generates is not useable.
regress log still shows same thing:
SET
BEGIN
psql:c:/projects/PostGIS/trunk/regress/postgis.sql:63: ERROR:
incompatible library "c:/projects/PostGIS/trunk/regress/00-regress-
install/lib/postgis-2.0.dll": missing magic block
HINT: Extension libraries are required to use the PG_MODULE_MAGIC macro.
I'm chekcing on my 8.4 now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:22>
