[postgis-devel] [raster] Implementations of rotation and pixel size.
dustymugs dustymugs at gmail.com
Thu Aug 18 16:19:29 PDT 2011
Hey David,
I've looked at the patch attached to #482 and find no issues with it.
Everything (merging, compilation, regression testing and checking for
memory leaks) looks good.
The only thing I changed with the patch remove the diff for
GNUmakefile.in, which is outside the raster directory.
I have no recommendation to setting a hard limit of 90 degrees for
RASTER_setRotation.  It makes sense to me but I'd hope that Pierre
chimes in.
On 08/18/2011 02:36 PM, David Zwarg wrote:
> Greetings raster devs,
> I took a day to implement the outstanding tickets that I had for some of the
> accessors related to rotated rasters:
>     - #928 - Implement ST_PixelWidth
>      <http://trac.osgeo.org/postgis/ticket/928>
>     - #929 - Implement ST_PixelHeight
>     <http://trac.osgeo.org/postgis/ticket/929>
>     - #936 - Implement ST_Rotation
>     <http://trac.osgeo.org/postgis/ticket/936>
>     - #482 - Implement ST_SetRotation<http://trac.osgeo.org/postgis/ticket/482>
> If someone could take a moment to review the patches attached to those
> tickets, that would be helpful. One of the things that I did not do was to
> limit the rotation amount in ST_SetRotation. I was reading more on the world
> file, and it sounds like a raster shouldn't be rotated more than 90 degrees
> -- should that be a hard limit in ST_Rotation?  If the rotation exceeds 90
> degrees, does the affine transformation go haywire? In addition, the
> UpperLeft position should realistically be changed. Otherwise, you could
> technically define different rasters that cover the same area, but with
> different UpperLeft coordinates (imagine if the geotransform put the
> UpperLeft pixel at the lower right, and applied a 180 degree rotation).
> Thanks,
> David
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
