[postgis-devel] [PostGIS] #1164: Add version information in liblwgeom
PostGIS trac at osgeo.org
Fri Aug 19 02:37:58 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 A liblwgeom client code should be able to tell liblwgeom version, and
 possibly also GEOS version it was built against, at compile time.
 Both versions would influence the set of available functions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1164>
