[postgis-devel] Languishing in a Linking Labyrinth (lwgeom_init_allocators)
Bryce L Nordgren bnordgren at gmail.com
Fri Aug 19 09:05:34 PDT 2011
I've been beating my head against quirky linking issues for the past couple
of days. This may be related to #1158, and may not be. I'm on arch linux
instead of windows, and I'm missing a different symbol in a different target
(lwgeom_init_allocators missing from rtpostgis-2.0.so instead of
PG_MODULE_MAGIC missing in postgis-2.0.dll). However, in both cases, the
linker just seems to be refusing to copy symbols to the destination, and in
both cases, the missing symbol is not directly referenced by anything else
which is being linked into the same target.  The effect is that compilation
completes successfully, but the shared library won't load. Note that when
libpgcommon is linked against postgis-2.0.so, the symbol is included. See:
[bnordgren at ghosty-mosty postgis]$ !nm
nm -a raster/rt_pg/rtpostgis-2.0.so | grep lwgeom_ini
                 U lwgeom_init_allocators
[bnordgren at ghosty-mosty postgis]$ nm -a postgis/postgis-2.0.so | grep
lwgeom_ini
0000000000045b80 T lwgeom_init_allocators
The most aggravating thing is that there's no observable reason for it;
while at the same time, it's reproducible.  Yesterday I identified "working"
and "non-working" commits in the git repo I'm using for raster iterator
development. Performing a "diff" on the build output revealed one extra
compile and one extra item on the linking line in /postgis (the commits were
"before/working" and "after/broken" for the patch on #1163). Well, my
problem is between libpgcommon and raster; postgis should have nothing to do
with it (and the symbol is present in postgis-2.0.so anyway).  The
working/non-working link commands which produce rtpostgis-2.0.so are line
for line and character-for-character identical, as is everything involving
the building of liblwgeom.a, libpgcommon.a, and everything in raster.
Here's the real kicker: I updated against svn this morning, reverting my own
local version of #1163 to bring in strk's. The update involves two
branches:  the branch containing my development code (branch ri-gen2-arch)
and the branch which reflects svn head + my own hardcoded adaptation to
address #960 on arch (branch archpostgis). Before the merge, both branches
were including lwgeom_init_allocators in rtpostgis-2.0.so. After the merge,
ri-gen2-arch is not including lwgeom_init_allocators. I can repeatably
checkout the pre-merge source, and everything is fine. Also reliably, I can
checkout the post-merge source and the symbol is missing.
So it's happened to me twice. This morning I reverted the commits which were
causing my issue yesterday, and this had become my pre-merge source which is
reliably working.  Strk re-introduced these changes to SVN via my patch on
#1163, and this became my "archpostgis" branch, which is reliably working.
Reunited, these two hard-working branches become broken.
The graphical depiction of my flailing around blindly may be found at:
https://github.com/bnordgren/postgis/network
Specifically, I have found that commits
fb7b369beade85f0c1dd<https://github.com/bnordgren/postgis/commit/fb7b369beade85f0c1dd62b7bea63971e149eebf>and
50fbb5ef6cf7c9deeaad<https://github.com/bnordgren/postgis/commit/50fbb5ef6cf7c9deeaad37a8f419c14f8ee971cc>include
the symbol, whereas commit
62a627b78779ce372c85<https://github.com/bnordgren/postgis/commit/62a627b78779ce372c85f4d87e50160eda520149>does
not.
Does anyone have any ideas?
Bryce
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110819/a7126740/attachment.html>
