[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
PostGIS trac at osgeo.org
Sat Aug 20 09:06:24 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 strk,
 Is that the right revision number.  That's going backwards no?
 For your other question.  My 9.0 works with changes (I mean the dlls are
 good the make check works for postgis), but the install fails with the
 above.  files are both good though postgis and raster .dll.  See my
 attached patch to get to the point I described.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:42>
