[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
PostGIS trac at osgeo.org
Sat Aug 20 11:34:55 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 1 step forward and 1 step back.
 I had to get rid of your ifdef 0 (blocking the module magic in rt_pg), for
 raster not to give the "you need magic" error during load.  Still needed
 the module magic patch for the postgis side.  Raster check still fails
 with
 In file included from ../../rt_core/rt_api.h:90,
                  from testapi.c:7:
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:23:22: proj_api.h: No such
 file or directory
                  from testapi.c:7:
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2194: error: syntax error
 before "lwproj_from_string"
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2194: warning: type
 defaults to `int' in declaration of `lwproj_from_string'
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2194: warning: data
 definition has no type or storage class
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2202: error: syntax error
 before "projPJ"
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2203: error: syntax error
 before "projPJ"
 make[3]: *** [testapi] Error 1
 make[3]: Leaving directory `/c/projects/PostGIS/trunk/raster/test/core'
 make[2]: *** [core-check] Error 2
 make[2]: Leaving directory `/c/projects/PostGIS/trunk/raster/test'
 though binaries after magic changes work fine.
 On the plus side, it does install now.  No longer get the "cannot create
 regular file `//_inst.2160_'" error any more.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:44>
