[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
PostGIS trac at osgeo.org
Sat Aug 20 20:20:58 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Okay restarting fixed my out of reserve space error, but the raster test
 api problem still exists.  If I do this
 cd raster/test
 make
 here is the log of what happens:
 make -C core check
 make[1]: Entering directory `/c/projects/postgis/trunk/raster/test/core'
 cc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-prototypes -I../../rt_core
 -Ic:/projects/PostGIS/trunk/liblwgeom -I/c/projects/GDAL/rel-trunk/include
 -o testapi testapi.c -lm ../../rt_core/librtcore.a
 c:/projects/PostGIS/trunk/liblwgeom/.libs/liblwgeom.a -L/c/projects/GDAL
 /rel-trunk/lib -lgdal
 In file included from ../../rt_core/rt_api.h:90,
                  from testapi.c:7:
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:23:22: proj_api.h: No such
 file or directory
                  from testapi.c:7:
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2190: error: syntax error
 before "lwproj_from_string"
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2190: warning: type
 defaults to `int' in declaration of `lwproj_from_string'
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2190: warning: data
 definition has no type or storage class
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2198: error: syntax error
 before "projPJ"
 c:/projects/PostGIS/trunk/liblwgeom/liblwgeom.h:2199: error: syntax error
 before "projPJ"
 make[1]: *** [testapi] Error 1
 make[1]: Leaving directory `/c/projects/postgis/trunk/raster/test/core'
 make: *** [core-check] Error 2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:48>
