[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
PostGIS trac at osgeo.org
Sat Aug 20 20:37:00 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Okay putting in the similar fix you did for raster fixed the test api
 issue.
 patched at r7774
 can people who are setup to compile and test raster verify my change
 didn't break anything.
 I'm going to test on my 8.4 and 9.1 installs and if those pass, then I'll
 close this ticket out.
 Thanks strk :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:50>
