[postgis-devel] [PostGIS] #1165: Selectivity extimation of && operator
trac at osgeo.org
Sun Aug 21 08:31:57 PDT 2011
Reporter: edoardopanfili | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by robe):
Edoardo,
join selectivity with LEFT JOINs is a known issue. FULL JOINS on a
spatial function aren't supported at all. As far as the join selectivity
issues, I'll let Paul or Mark comment on those since I'm not sure how all
that works. I do know I've had a lot of selectivity issues (particularly
with tiger geocoder) which I have worked around by using WITH queries to
control the plan as you have. I wasn't really sure where to put the blame
since a lot of those were just plain attribute queries.
I am more concerned about your 2.0 issues. Which subversion revision
number are you using of PostGIS 2.0? Are the plans the same as on your
1.5? Is your 2.0 installed on the same version of PostgreSQL as your 1.5?
I've loaded a couple of my production databases using PostGIS 2.0 (about
2-3 week old release on Windows), and haven't noticed any major noticeable
differences. Some things are a slower but not by much and some things are
faster (which seems to be more to do with the higher accuracy of the
bounding box in 2.0)
Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1165#comment:1>
