[postgis-devel] [PostGIS] #1166: [raster] check failures under windows 9.1beta3 mingw compiled
PostGIS trac at osgeo.org
Sun Aug 21 08:50:13 PDT 2011
  Reporter:  robe            |       Owner:  pracine
      Type:  defect          |      Status:  closed
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  invalid         |    Keywords:
Comment(by dustymugs):
 It looks like in 9.1, the devs added something to check the printf type in
 src/include/pg_config_manual.h.  If you take a look at line 157 to 171,
 the behavior changes for Win32.  Is it possible that you may need the
 lastest mingw to eliminate that warning?  Or try modifying those lines in
 pg_config_manual.h to for force printf rather than gnu_printf?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1166#comment:2>
