[postgis-devel] [PostGIS] #1165: Selectivity extimation of && operator
PostGIS trac at osgeo.org
Mon Aug 22 20:24:47 PDT 2011
 Reporter:  edoardopanfili  |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis         |     Version:  1.5.X
 Keywords:                  |
Comment(by robe):
 what's the easiest way to tell once its compiled.  I'm pretty sure its ON
 since its the one I've been testing with where I said the size of the
 geometries was bigger.  Wouldn't a bigger geometry suggest GSERIALIZED ON
 or is there a better way.
 I also assume it is because I remember when I swapped binaries with one
 GSERIALIZE ON or off I get weird errors since the two geometry types are
 incompatible.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1165#comment:8>
