[postgis-devel] [PostGIS] #318: 900913->4326 Transform
PostGIS trac at osgeo.org
Fri Aug 26 03:41:46 PDT 2011
 Reporter:  pramsey  |       Owner:  mcayland
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.4.3
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by kbayram):
 * cc: kbayram (added)
Comment:
 I came across this bug and Google brought me here.  I've managed to fix
 the problem in my case and it turns out it was a extremely trivial
 problem.
 If you do a "select * from spatial_ref_sys where srid = 900913;" in psql
 you may notice that the text in the srtext and proj4text has line feeds.
 It turns out that proj4 does not like these and anything after the first
 line in the proj4text field is ignored, namely the important
 nadgrids=@null which causes the error.
 Removing the line feeds solved the problem for me.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:26>
