[postgis-devel] [PostGIS] #1173: TopologyException from intersection of valid geography
trac at osgeo.org
Fri Aug 26 10:06:10 PDT 2011
Reporter: jgilman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
I have a polygon that wraps around the north pole. When I do an
intersection with this polygon and a point below the equator I get a
TopologyException.
SQL:
select ST_AsText( ST_Intersection( ST_GeogFromText( 'SRID=4326;POLYGON((45
80,135 80,-135 80,-45 80,45 80))' ), ST_GeogFromText( 'SRID=4326;POINT(45
-70)' ) ) );
Result:
NOTICE: TopologyException: found non-noded intersection between
LINESTRING (5.00938e+06 1.54966e+07, 1.50281e+07 1.54966e+07) and
LINESTRING (1.50281e+07 1.54966e+07, -1.50281e+07 1.54966e+07) at
CONTEXT: SQL function "st_intersection" statement 1
ERROR: GEOS Intersection() threw an error!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1173>
