[postgis-devel] [PostGIS] #1174: [raster] C-level index-to-geocoordinate functions
PostGIS trac at osgeo.org
Fri Aug 26 19:02:49 PDT 2011
 Reporter:  bnordgren       |       Owner:  pracine
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  1.5.X
 Keywords:                  |
 Primarily, this patch adds a geocoordinate-to-index function for raster at
 the C level.
 The attached patch changes the internal structure of `rt_raster` such that
 it stores forward and reverse affine transformations between pixel index
 coordinates and geospatial coordinates. The inverse transform is also
 stored in "struct rt_raster_t" and is automatically recomputed when the
 accessors are used to change the affine transform parameters. Tidied up
 the code in rt_api.c to ensure it uses accessors.
 The serialized structure is left unchanged, but it is no longer possible
 to memcpy between struct rt_raster_t and struct rt_raster_serialized_t.
 All tests pass. Patch applies against r7789
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1174>
