[postgis-devel] loading a raster with overview fails
John Thakkar
thakkar at nexgenwireless.com
Wed Aug 31 13:07:49 PDT 2011
It looks like ticket #1151 has been opened by pracine for this based on my
last email to the group. Thanks!
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of John
Thakkar
Sent: Wednesday, August 31, 2011 2:43 PM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] loading a raster with overview fails
I'm trying to load overviews for a raster with this command.
/usr/local/pgsql/bin/gdal2wktraster.py -s 26918 -M -I -v -V -l 4 -k 256x256
-r raster.grd -t schema.mytablename
It fails with this information.
File "/usr/local/pgsql/bin/gdal2wktraster.py", line 1014, in <module>
main()
File "/usr/local/pgsql/bin/gdal2wktraster.py", line 977, in main
wkblify_raster(opts, filename, i)
File "/usr/local/pgsql/bin/gdal2wktraster.py", line 922, in wkblify_raster
summary = wkblify_raster_level(options, ds, options.overview_level,
band_range, infile, i)
File "/usr/local/pgsql/bin/gdal2wktraster.py", line 889, in
hexwkb += wkblify_band(options, band, level, xoff, yoff, read_block_size,
block_size, infile, b)
File "/usr/local/pgsql/bin/gdal2wktraster.py", line 797, in wkblify_band
out_pixels[row] = out_line
ValueError: shape mismatch: objects cannot be broadcast to a single shape
It seems to write the entire SQL properly but seems to fail while inserting?
Here is the gdal info on the file.
Driver: NWT_GRD/Northwood Numeric Grid Format .grd/.tab
Files: raster.grd
Size is 1293, 1276
Coordinate System is:
PROJCS["unnamed",
GEOGCS["unnamed",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 80",6378137,298.257222101],
TOWGS84[0,0,0,-0,-0,-0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-75],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Origin = (306885.000000000000000,4328685.000000000000000)
Pixel Size = (30.000000000000000,-30.000000000000000)
Corner Coordinates:
Upper Left ( 306885.000, 4328685.000) ( 77d13'57.95"W, 39d 5' 9.33"N)
Lower Left ( 306885.000, 4290405.000) ( 77d13'19.14"W, 38d44'28.42"N)
Upper Right ( 345675.000, 4328685.000) ( 76d47' 4.23"W, 39d 5'37.14"N)
Lower Right ( 345675.000, 4290405.000) ( 76d46'33.21"W, 38d44'55.89"N)
Center ( 326280.000, 4309545.000) ( 77d 0'13.63"W, 38d55' 3.48"N)
Band 1 Block=1293x1 Type=Byte, ColorInterp=Red
NoData Value=0
Band 2 Block=1293x1 Type=Byte, ColorInterp=Green
NoData Value=0
Band 3 Block=1293x1 Type=Byte, ColorInterp=Blue
NoData Value=0
Band 4 Block=1293x1 Type=Float32, ColorInterp=Undefined
NoData Value=0
Offset: -100, Scale:0.00305185094759972
Any help would be appreciated.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110831/b1fb1723/attachment.html>
