[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with AddRasterConstraints and expand # of constraints on raster columns
trac at osgeo.org
Thu Dec 1 13:22:02 PST 2011
raster columns
Reporter: robe | Owner: dustymugs
Type: task | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by mloskot):
Replying to [comment:39 dustymugs]:
> Replying to [comment:37 mloskot]:
> > Please, with all my respect, don't be scientific-ignorant here guys
and don't make PostGIS Raster just another GRASS, please.
> scientific-ignorant? You'll have to elaborate on that.
I have a constant impression that the PostGIS Raster is becoming more
fully-featured analytical GIS system where storage use cases are
forgotten.
I apologies if I've touched you or anyone.
> > If you decide to get rid of this flag, then the only way to determine
if a table is tiles storage or not is to perform slow (!) query.
> From the looks of it in the AddRasterColumn function, regular_blocking
is just a boolean value passed with no true validation of making sure
> that no tiles overlap and there are no gaps. As the appropriate
constraints won't be added until after PostGIS 2.0 is released, we could
just
> add a garbage constraint to indicate that a column is regularly blocked.
AFAIR, constraint on regular blocking has never been planned. It would be
slow anyway.
The uploader is supposed to play the key role here and take care of
assuring tiles in a table are regularly
blocked if such configuration is requested.
IMHO, the fact that there is no constraint attached does not make the flag
useless or invalid concept.
> > Per analogia, where vector folks here store SRID information?
> You're going to have to be more descriptive here.
Nevermind, this is wrong analogy.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1319#comment:42>
