[postgis-devel] [PostGIS] #1347: postgis_upgrade_minor.sql fails as can't drop aggregate
PostGIS trac at osgeo.org
Fri Dec 2 10:06:54 PST 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 when you have views using aggregates you can't drop them (the aggregates).
 This makes current postgis_upgrade_xxx.sql script bail out:
 psql:postgis/postgis_upgrade_20_minor.sql:1856: ERROR:  cannot drop
 function st_union(geometry) because other objects depend on it
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1347>
