[postgis-devel] [PostGIS] #877: st_estimated_extent returns error on empty table
PostGIS trac at osgeo.org
Thu Dec 8 03:31:23 PST 2011
 Reporter:  martins  |       Owner:  strk
     Type:  defect   |      Status:  assigned
 Priority:  high     |   Milestone:  PostGIS 1.5.4
Component:  postgis  |     Version:  1.5.X
 Keywords:  history  |
Changes (by strk):
  * keywords:  => history
Comment:
 Fixed by r8319 in trunk and r8317 in 1.7 branch.
 Documentation would need to be tweaked to reflect the semantic change. Not
 sure which expressions to use there. Robe ?
 Speaking of which, I've seen we advertise "VACUUM ANALYZE" as being the
 command gathering the statistics while "ANALYZE" is enough (and tested now
 within regress/ticket.sql)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/877#comment:9>
